looper222
another element ID manager issue
maybe somebody can help this time. i have a list of rules set up for the element ID manager, they are saved under a name that i choose. when i give the project to someone else to work on (it is taken to another computer) and they want to go and re-id the windows, the ID criteria that i set up is not there, and i can't seem to find any way to load it?
i have been able to transport my schedule settings by copying and assigning a settings folder... is there anything like this for the element ID manager settings?
carl
1 Reply 1
Yes, but undocumented (of course!). Just tracked it down for you. If you are using Windows, you will find the settings in a folder named EIDM located at:
c:\Documents and Settings\USERNAME\Application Data\Graphisoft\EIDM
Presumably you can just copy that to the corresponding location on the other machine (and user account).
I've added a wishlist item that this be managed more effectively. Please go vote at:
http://archicad-talk.graphisoft.com/viewtopic.php?p=10361#10361
