another favorites question
is there a way to set up tabs in the favorites pallete to switch back and forth between two of my favorite favorite pallettes?
5 Replies 5
also is there a way to keep the same layers with the favorites. when i import the favorites into a new drawing the layers aren't the same sometimes and i have to go back through and redefine all the favorites
Yes. Go to your favorites preferences. Here you can set various parameters to change (or not change) when you apply the favorite. If you tick the 'Layers' box, then when you apply a favorite to something in your drawing and the layer won't change. Sorry about the vague explanation, hope it's of some use though.
I don't think there are tabs or any other way of organising favorites, some folders or something would be really useful.
Maybe I was to vague. I was wondering if when a favorite is loaded into the pallete if the layer that were missing for the particular tools could be imported. Is there a way to save and load a list of Layers? And if so, how? It would also be nice to see the favorited pallete set up like the navigator with the tabs at the top and a way to switch between one pallete to another.
David Maudlin
Jeremy:
Layers and Layer Combinations (as well as other file attributes) can be loaded from other ArchiCAD files using Attribute Manager, found under the Options menu.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Great Thanx Guys
