arc tangent to two arcs or circles
How can be done an arc tangent to a line and an arc or circle, or maybe just tangente to two arcs or circles? Should I revisit my geometry books? They're full covered with dust. mmmmm
8 Replies 8
Petros Ioannou
I believe Archiruler from Cigraph will answer all your questions.(both geometry and texture fills).
visit : www.cigraph-store.com
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
__archiben
two topics in the 'tips and tricks' forum:
http://archicad-talk.graphisoft.com/viewtopic.php?t=485
and
http://archicad-talk.graphisoft.com/viewtopic.php?t=486
(it's worth doing a search sometimes )
~/archiben
b e n _ f r o s t
To Ben: I'm looking for a circle, not for a line. And the links are very similar to what I've found in my geometry book. (i've had to clean the dust). And really, I think both things should be done within Archicad with object references
To Petros, I think Archiruler can't solve a circle tangent to two circles, I tried but I couldn't, maybe I miss something. I'll look better.... don't know about fills with textures, but I'll look too
Thanks for all
__archiben
oops
should've read your question, eh? sorry.
~/archiben
b e n _ f r o s t
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
The attached image shows you where these commands are located in the ArchiRuler 2.0 palette...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Here is the geometric method I use to get a circle tangent to two other circles. It takes a few clicks, but its not too bad once you get used to it.
Basically, you striike two arcs and place the new circle at the intersection.
The first arc has radius = (new circle radius) + (radius of circle #1), and the arc is centered on circle #1.
The second arc has radius = (new circle radius) + (radius of circle #2), and is centered on circle #2.
[/img]
Karl,
That works very nicely.
Thank you for the geometry lesson.
Peter Devlin
the Archiruler suggestion was spot on. I too wanted to draw a circle tangential to two circles. it is very very easy with Archiruler at ones disposal. I have introduced it to my firm and we will be looking purchase more copies.
welldone fabrizio.
