archicad 28, cant find MEP routing anywhere.
DanyThailand
cant find MEP routing anywhere, cant edit elbow size individualy, what's happen ?
4 REPLIES 4
More details?  Are you working on an old project?  What version was it created in?  Graphisoft totally changed MEP recently, so "old MEP" must be edited in the old version of Archicad as the "new" MEP does not recognize it.  (Don't shoot the messenger... you'll find a lot of discussion about the unhappiness over the changes to MEP if you search the Community.)
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
no, it's a blank new file with archicad 28, just wanted to see how mep works. Can place piping etc but cant find the mep routing, i search everywhere 😞
@DanyThailand,
Do you have an MEP Profile activated in your Work Environment? That should display the MEP Tools in your Toolbox.
yes, it is activated, i read that mep routing doesnt exist anymore as Karl said. How do you change direction ( for example to go up ) when you draw on floor plan ?
Setup info provided by author
