beutiful elevation ...How?
AC has many possibility for the presentations.
How do you make beutiful elevation with AC?
Rendered elevation ist Bitmap, not so good for elevation...or?
Here are some examples.
http://www.graphisoft.de/produkte/referenzen/plan/feb_2005/
10 Replies 10
samsung wrote:
Maurice wrote:
And don't forget you can do "quick sketch" like views used a saved .pmk file with lines converted to wiggly sketch style, then overlaid with a rendered image (I like to edit in an image editor and use a slight blur filter over it)
It looks very nice. But I can't understand exactly, how you use the technique with pmk file...
It would be great, if you can explain more detailed...
In Plotmaker ...
Create a hidden line view using 3d internal engine and save the 3d view as a plotmaker file "*.pmk*. Open it in plotmaker (not archicad), select all and change line type to sketch style line. Save again. From plotmaker overlay rendered image with "*.pmk* file to achieve effect.
In Archicad ...
You can also save a 3d view in hidden line view using 3d internal engine and and save as Archicad 2dl. Open in archicad, cut & paste into your model (plan or unlinked elevation) with the rendered image brought in as a figure.
