can i hide the objects under handril in 2d representation?
Hi everyone i need to hide the objects in 2d representation that i made under handril (the handril created by wall profile manager) so i need to hide the objects that under handril because represenation of railing in 2d drawing submisson can not be by this way
and thanks in advance for offering help
4 Replies 4
Erika Epstein
a solution is to place those elements not to be seen in plan views on a layer that is not visible in plan layer combinations.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
but could this effect the visibilty of objects in 3d as well ?
Use different layer combination for 3D. In fact the plan view combo that hides the balusters is only really needed for output (assigned to plan views in the view map) unless you are really bothered seeing them in plan while you're working on the model.
Dwight
You might also consider altering the plan representation:
Bring the wall profile to the front in display order.
Give the wall profile an opaque cut fill -- see attached.
Define the wall presentation as "Symbolic cut"
Dwight Atkinson
