can't get hatch to show when using zone tool
For some reasons, when I create zones on my plans using the zone tool, I can't get any hatch or boundary to show. All that shows up is the zone stamp. I'm using AC10. Thanks
Check in: Document > Model View Options
There are settings for zone display/printing. You should save different View Option settings for different views/drawings. For example: you probably want the zone fill on in your floor plan but not in the RCP, and the zone color usual only appears in area plans (if at all).
It worked,
Thanks
