changing fonts and lines based on layer
cocoloco
Hello!
'Is there a way to change all text same based by Layer? yes I know how to change text, all text, ... but I need to change text size/font based on layer, the same with lines..... turning off and on layers is lame option, anything else please?
after this huge upgrade in Archicad on layers, like now we can search through them (😵) I am sure something like this is there I just had not discovered it?
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
2 ACCEPTED SOLUTIONS
Have a look here ... Help: Find & Select
You use find and select an set the criteria to text and then add additional criteria, in your case you add Layer
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC28 | WIN 11 | i9-10900K, 3.7Ghz | 32GB Ram | NVIDIA GeForce RTX
3070
5 REPLIES 5
Just use find and select, and make the criteria Text and the Layer you want to change. Will only work per storey/view though. It won't change it globally.
Director | Skewed
3070
hi!
I chosen element type = text but it selects all. (Even when I select layer on Frontend). I don’t see any other layer setting. Please could you show me printscreen ?🙏🙏
Director | Skewed
3070
this is perfect thank you so much!!!! Very helpful to see it in print screen and I already tried and it works 🤗  If I only knew before..
