contour mesh
ahmad525
hey all
im trying to create the contour lines mesh but for some reason creating the contours isnt actually following the contours spline lines from the survey.
please refer to images. (this is an example spline lines )
You need to adjust the magic wand settings to get a better curve.
thanks mate !
