copy/paste from section/elevation to plan
ever since I use archi cad 8.0 and 8.1, i encounter a problem which seems impossible to solve:
i often copy from the section/elevation and paste the view in the floor plan in order to draw all the details necessary in a section/ facade. In 7.0 it worked great, but in 8.0 and 8.1 the lines and fills pasted in the floor plan become impossible to select or even invisible. If i restart ArchiCAD it works but only a few moves. Why ?
5 Replies 5
Djordje
Not really clear what your problem is; however, is there a real NEED to copy and paste into the plan? Can you not work directly in the S/E or Detail windows? If S/E speed is a concern, switch the S/E to zero depth - it is quite fast and intended for use just in situations liek the one you mention.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
one of the advantages was that were less pmk. files to import into pltmaker.
for example one floor plan contained all the sections and facades.
Mihai
Djordje
Mihai wrote:
one of the advantages was that were less pmk. files to import into pltmaker. for example one floor plan contained all the sections and facades.
Don't do that ... ArchiCAD is NOT the place to do it. No harm in PMKs also, especially ow that we have the linked views and layout books.
Do yourself a favour and don't do any layouting in ArchiCAD.
Djordje
HP Omen
Ben Odonnell
Couldn't agree with you more Djordje. It will slow down the whole working process of ArchiCAD. Plotmaker is definitely the program for your layouts. Plotmaker is very robust and made for doing layouts.
Take Djordje's advice and start using Plotmaker.
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
however i wanted to emphasize a function which in 7.0 perfectly worked but in newer versions 8.0 and 8.1 cause serious malfunction
