copy rotate
ok gang how do you copy rotate multiple times the objects in red.....
10 Replies 10
r wrote:
I am surprised that I can't drag and copy in a circular wall...and you should see the size this building I am working on....anyway I will survive....I am hoping in the future there is an ALTERNATIVE in copying doors....especially if you different types...I like the feature of drag/copy, but there needs to be more.....
I'm using V81 and have no problem with DRAG or DRAG A COPY of doors in curved walls.
But you can't select the walls and door together and drag copies of them all at the same time as mentioned already.
Sometimes if an option doesn't appear in a right-click menu you may find it in the pull-down menu.
Mine shows up with right-click.
