Text Selection in Marquee
Tom Krowka
I'm trying to select a certain text string that is repeated throughout the plan and change it. Is there any way to do with the marquee tool. I can select all the text within the marquee. What I'd like to do is select only the certain text, then change all that text at once, rather than one text block at a time.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
2 REPLIES 2
Yes,
1. draw marquee
2. go to Menu: Edit>Search And Replace Text...
3. use filters. Here under search "on current story" and "in all stories" you will not find search only in marquee, but it steel works.
have fun
Tom Krowka
Thanks. Never knew that was there......
Thomas@wkarchwk.com
www.walshkrowka.com
