2007-04-13
12:00 PM
2023-05-26
02:59 PM
Rubia Torres
2007-04-13 12:31 PM
2007-04-13 01:59 PM
NAB wrote:If you've got a solution, go with it. It's a tricky situation (though not uncommon). Columns and walls interact automatically and this leads to some occasional quirky behavior (for what it's worth, it has improved a lot since the column tool was first introduced).
I can solve it using the wall tool to make the pillars (metal).
I´m not sure this is the best way to do it though.
2007-04-13 02:22 PM
Matthew wrote:Columns in this situations I'm always putting in a new layer, called for example Windowcolums and set layerindex to anything different than the normal number for walls and columns.
2007-04-13 02:25 PM
TurboGlider wrote:Mmm, that would to do it too. Good idea.Matthew wrote:Columns in this situations I'm always putting in a new layer, called for example Windowcolums and set layerindex to anything different than the normal number for walls and columns.
2007-04-13 03:06 PM
2007-04-13 03:12 PM
TurboGlider wrote:Yes, that's a big pain. Layer combinations are a maintenance headache.
One important thing with layerindex is that all layercombinations have to be updated because a new layer created after a layercombination always got layerindex = 1 in every combination.
WHY???
