2005-06-30 05:56 AM
2005-06-30 06:05 AM
2005-06-30 07:59 AM
2005-06-30 10:42 PM
2005-06-30 11:29 PM
2005-06-30 11:38 PM
2005-06-30 11:41 PM
Onho wrote:I am assuming that you are seeing the fill pattern through the fixtures. If the fixtures are completely obscured then it is a display order problem (Tools menu).
i got a toilet and vanity and bath in one room, how do i put the tile (fill) in it without XXXXXover bath and toilet.
onho
2005-06-30 11:47 PM
s2art wrote:Pens 0 and -1 are special pens which can only be used for backgrounds. If you set them as the fill pen (i.e. to draw lines, or solid cover) then you will get this error.
Wes
Just tried that and got this message....
2005-06-30 11:51 PM
Matthew wrote:So use it for the fill background pen, not the fill pen itself. Got it, thanks.s2art wrote:Pens 0 and -1 are special pens which can only be used for backgrounds. If you set them as the fill pen (i.e. to draw lines, or solid cover) then you will get this error.
Wes
2005-07-01 01:01 AM
