Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
cursor trace lines dont appear in Release 14
intermittently the trace guidelines for my cursor - for example when i am trying to select objects to move/edit, disappear altogether - so i cannot tell accurately what is being selected. Anyone else have similar problems? Or perhaps suggest what the problem might be. We are currently using ArchiCAD at 3 workstations (all exactly the same spec) and it only happens on my machine.
1 REPLY 1
Sometimes a restart will fix the problem.
But it may come back at any time.
I would try updating your video card driver if restarting doesn't work or it is a persistent problem.
