curtain wall door
hi all
im using the curtain wall door (single door) and the door is allways open in 90'. in the double door theres an option (like in other doors) to keep the door closed but not in the single door.
isnt it odd that the option exists for the single door but not the double?
in any case does anyone know how can i solve this?
im using archicad 8 by the way..
tnx in advance!
3 REPLIES 3
David Maudlin
only:
In the ArchiCAD Library 81, 08 Doors-Windows 81 > Curtain Walls 81 is a door part: D Curtain Wall Door. In the Parameters section of this library part look under 3D Representation there is a parameter "Opening Angle in 3D", this controls the door angle in the model. Under 2D Representation there is a parameter "Opening Angle in 2D", this controls the door angle in the plan view. If this doesn't answer your question, please post more information about the part you are using.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thomas Holm
As David shows, those functions are available in the Archicad 8.1 library. If you have a legit license for Archicad 8, Archicad 8.1 is a free upgrade. You should contact the nearest reseller to get it at once. It corrects a lot of bugs and adds some features.
got it
cheers for the reply!
