FOR THE CURTAIN WALL TOOL IS THERE A WAY TO EDIT HEIGHT WITHOUT REDRAWING THE ENTIRE WALL. ALSO I HAVE THE WALL SET UP TO SHOW THE SPIDER CLIPS BUT THEY DONT SHOW...
To edit the boundary of the Curtain Wall in 3D, you will have to make the Scheme visible. It is more convenient to hide the Frames and Panels at the same time. Then it will be easy to see the thick boundary of the Curtain Wall which you can edit like any other polygon in AC.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
how do you create a curtain like the one shown in the sample picture. in the setting box it will only let you rotate horizontal elements.... i want a 45/45 basically x pattern.
Ummm... WHICH sample picture? Very few mind readers present here. 😉
Also... please do not start new topics with the same name as an old topic which you also started. Use a subject name that accurately describes the gist of your question. I've merged your two curtain wall topics for now...
Hi, not sure if this helps, but you can easily change the horizontal members to 45 degrees in the properties section, in the area where you define the sizes of the members. I have however not found how to modify the vertical members, I do vaguely remember there being something to do with that in the ArchiCAD help under Curtain Wall but am not sure if it fully answers your question.
