2009-05-01 11:05 AM
2009-05-01 02:30 PM
hunya wrote:If you use the Search feature of the forum and search for curtain AND wall AND angle, you will get some threads about this, such as:
heey, i'am still new to archicad and i'am trying to develop a curtain wall that has slanted- crossed frames like the building tha appears when you open the archicad, is there is an easy way to do that or can i import or add an add on or sth??
2009-05-01 09:39 PM
2009-05-01 11:09 PM
2009-05-02 08:15 AM
2009-05-02 12:29 PM
hunya wrote:Complex profile is the name of the tool, not its characteristics. You just draw a contour shape with fills, save it and then apply it to a wall or a beam or column. Try to read the docs, do step-by-step what the Help file says. (Remember: right-click when you're in a tool dialog takes you to the right place in the Help file)
hey thanks i discovered that archicad is not limited as i thought before, but those are too complex for me since i was just starting to learn how to curve a wall two weeks agoi was thinking of making small cylindrical wall segments and connect them or sth that would be easy at my level,
pls if you have other thughts share them with methanks
