Solid Element Operation :S
hey i'am having a problem in hiding the operator in the SEO, i followed each step that i could find so far, but when i tried to hide any layer, both the operator and the target disappear!!!, could anyone tell me how i should specifically do that cause it is driving me crazy and i really need it, thanks
Thomas Holm
- Create a dedicated operator layer, where only SEO operators that should be hidden later reside.
- Save a 'work' layer combination with this layer visible.
- After you've done the SEO operation, hide this layer only.
- Save a 'final' layer combination with this layer hidden.
- Save a view with this layer combo active, and you'll be able to get back to it with just a click in the Navigator, and you can easily place it on your layouts for later publishing.
thanks i will try that
