curtain walls
How do i create a curved curtain wall or replica? Not as easy as that unfortunately. The curve is irregular, imagine a banana with 30% of it straight at one end. In plan thats what i need to do. Ive at the minute only created a glass wall. Its just not looking too good in the rendering.
4 REPLIES 4
for got to mention the top is sloped from 3200 to 3000mm
thanks
hmm is separate windows trimed to roof the only way?
David Larrew
Have you tried "ArchiGlazing"?
http://www.graphisoft.com/products/productivity_tools/tools/archiglazing.html
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Can you not use the 'Curtain Wall Curved' object under 08 Doors-Windows? Might need two with different radii to get the shape...in conjunction with a straight section perhaps? To do the top trimming, you'll have to use a roof or a subtraction via SEOps.
Just a thought...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
archiglazing .. yet more money, think ill just leave the mullions out of this shot
