Learn more
curve windows
hi all
how I can make windows like this curve in plane and curve in elevation
and If I use curtain wall who I can make hole in wall same my curtain windows
thank
2 Replies 2
vfrontiers
I am presuming you can't get what you want with the ArchTop Window...
I would simply place and ARCHED OPENING in the REGULAR WALL... then ADD a curtain wall along the radius (as a separate entity)... It will not be ARCHED, but no one will know as the corners will be hidden inside the regular wall....
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
David Maudlin
You can approximate the arch with straight segments (all pieces of curtain wall are straight) by using a fill to define the boundary, see the Help files for: Virtual Building > Construction Elements > Curtain Wall: A System Tool > Edit Curtain Wall Boundary in Section.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
