curved roof and cadimage roof builder
I've curved roof built by 'mesh to roof' . 'the mesh to roof' generate that roof become segmented. is it possible if i draw curved roof not in segmented (one part curved roof)?
then i'll using cadimage roof builder so my curved roof have looks like simple roof as image i attached.
thanks
3 Replies 3
Djordje
Not as a roof.
You can use the Profiler, or a Custom profile wall or a beam.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Also not as a roof - but it appears that the curve on one side is different than the curve on the other. The complex profiles cannot create such an extrusion - however Cigraph's ArchiForma can, and I suspect that Objective and Cadimages profiler might be able to as well?
Karl
thanks
Using the mesh to roof creates a LOT of roofs. Cadimage Accessories will place a unique object for EACH of them. I'm not sure that's what you want.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
