‎2006-10-10
12:05 PM
‎2023-05-25
05:58 PM
Rubia Torres
‎2006-10-10 12:16 PM
‎2006-10-10 03:52 PM
‎2006-10-10 05:57 PM
jdk wrote:That works already, more or less, IF the line is a vector (line or polyline or curve).
...a magic wand that translates any line under the cursor as "part of" the slab, it then draws the edge of the slab...
‎2006-10-10 06:29 PM
‎2006-10-10 06:34 PM
Thomas wrote:Even worse...
No matter how good the original drawings, the paper copies scanned, the scanner and the software is, you will get a result with more errors to correct than acceptable for BIM work!
‎2006-10-10 06:40 PM
jdk wrote:What advantage do you see to this as opposed to accurately tracing the drawing using the tools we already have?
Although a magic wand could be affected by the similar problem, it could be easier to manage, as it would be limited to one segment at the time, the one under the cursor, instead of making guess work with all the imperfections of an old technical drawing.
‎2006-10-10 07:08 PM
‎2006-10-10 07:09 PM
‎2006-10-10 07:14 PM
