cycloid
adbestias
hi!
i work with archicad 11 on windows vista and i need to draw a cycloid; is there a way to do it? is there any generator?
thank you...
13 REPLIES 13
Are you looking to include gravity in this or just the path that a point on a circle takes as it rolls? Either way it doesn't look like an easy task.
adbestias
hi! (i'm not sure if i understood «include gravity».)
i need to create a roof wich form is generated by a cycloid; the only way i see to do this is by creating a complex profile with the cycloid, and then the roof.
thank you!
This is a good start.en.wikipedia.org/wiki/Cycloid I've given it a shot but scripting this thing is above me so far. Maybe some guru with some spare time could show us the way! Doug
You can create an new GDL object
and use the parametric equation of a
cycloid ?
all the best
Jean-Luc
---------3D script------------------------
R=10
ROTY 45
TUBE 4, 12, 16+32,
-----4 nodes for the rectangle---------
2.0, 0.0, 0,
0.0, 0.0, 0,
0.0, 0.4, 0,
2.0, 0.4, 0,
---------12 nodes to describe the 3d cycloid curve-------
R*(15*pi/180-sin(15)),0, R*(1-cos(15)), 0,
R*(30*pi/180-sin(30)),0, R*(1-cos(30)), 0,
R*(45*pi/180-sin(45)),0, R*(1-cos(45)), 0,
R*(60*pi/180-sin(60)),0, R*(1-cos(60)), 0,
R*(75*pi/180-sin(75)),0, R*(1-cos(75)), 0,
R*(90*pi/180-sin(90)),0, R*(1-cos(90)), 0,
R*(105*pi/180-sin(105)),0, R*(1-cos(105)), 0,
R*(120*pi/180-sin(120)),0, R*(1-cos(120)), 0,
R*(135*pi/180-sin(135)),0, R*(1-cos(135)), 0,
R*(150*pi/180-sin(150)),0, R*(1-cos(150)), 0,
R*(165*pi/180-sin(165)),0, R*(1-cos(165)), 0,
R*(180*pi/180-sin(180)),0, R*(1-cos(180)), 0
Who will notice the difference?!? šŸ˜‰
I thought of that too Kliment. Just seemed too easy!
may be it matters to people
dealing with strength of materials ?
thank you!
Create a Barrel-Vaulted Roof
Roof Tool > Barrel Vaulted > Click on Cycloid by Magic Wand
That diagram is a work of art, Beart!
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
