cyrillic in zone stamps?
writing in cyrillic in AC9 with the text tool i've had almost no problems.
i've had some trouble with the label tool, until i figured out that as long as i do not attempt to write in the dialog box, but rather directly on the plan, it works out ok.
but now i need a zone stamp in cyrillic, and writing in the dialog box obviously doesn't work, but since it is a stamp, it doesn't allow me to write directly on the plan.
is there a way to bypass that?
thanks.
are You on mac or pc?
if on mac, You'll need an pp that can read&write plist files. omni outliner is solution for me. check out if /archicad.app/contents/info.plist key CFBundleLocalizations contain "ru"
if on pc- there was a solution here in forum. http://archicad-talk.graphisoft.com/viewtopic.php?t=1813&highlight=font+registry
replace HKEY_CURRENT_USER/Software/Graphisoft/ArchiCAD/ArchiCAD WHATEVER INT/Font Description value to 204
i'll try it.
i missed that thread when i searched the forum.
thanks!
