detail tool
alemanda
is there any way to not see (or to not generate) the boundaries in the details or working sheets?
Thanks.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
5 REPLIES 5
alemanda
...mmmm.
Is there any way to resize the detail polygon in order to take into consideration a wider area of the drawing?
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
alemanda wrote:
...mmmm.
Yes - but like modifying a variety of other things, not immediately obvious.
You must enable viewing "Marker Range" in the onscreen viewing options. View > Onscreen View Options > Marker Range. This will display a bounding rectangle around the detail bubble, and you can use all pet palette polygon editing tools there.
I typically have the standard toolbar for Onscreen View Options visible so that I can just click a button when I need to turn this on/off for editing.
alemanda
Thank you very much...and what about the boundaries? Is it possible to not generate them?
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Greg A_ Blunier
When you create a new Detail or Worksheet viewpoint using a polygon input method, the resulting drawing will show the Boundary as a dashed line. If you do not want this boundary included in the Drawing window, disable the relevant checkbox in Options > Work Environment > More Options.
ArchiCAD 28 USA Full and ArchiCAD 22 & 7
Windows 11
alemanda
Finally!!!
Thank you.
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
