alemanda
detail tool
is there any way to not see (or to not generate) the boundaries in the details or working sheets?
Thanks.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
5 Replies 5
alemanda
...mmmm.
Is there any way to resize the detail polygon in order to take into consideration a wider area of the drawing?
AC27 latest hotfix
Win 11 Pro 64bit
alemanda wrote:
...mmmm.
Yes - but like modifying a variety of other things, not immediately obvious.
You must enable viewing "Marker Range" in the onscreen viewing options. View > Onscreen View Options > Marker Range. This will display a bounding rectangle around the detail bubble, and you can use all pet palette polygon editing tools there.
I typically have the standard toolbar for Onscreen View Options visible so that I can just click a button when I need to turn this on/off for editing.
Karl
alemanda
Thank you very much...and what about the boundaries? Is it possible to not generate them?
AC27 latest hotfix
Win 11 Pro 64bit
Greg A_ Blunier
When you create a new Detail or Worksheet viewpoint using a polygon input method, the resulting drawing will show the Boundary as a dashed line. If you do not want this boundary included in the Drawing window, disable the relevant checkbox in Options > Work Environment > More Options.
ArchiCAD 28 USA Full and ArchiCAD 22 & 7
Windows 11
alemanda
Finally!!!
Thank you.
AC27 latest hotfix
Win 11 Pro 64bit
