display order issues
ares997
So I have a few objects that say that are at the top of the stack yet they technically are not at the top. Even if I try and drop a few of the objects to the bottom they don't get below a few other objects. One of the objects is a hotlink module and the others are fills over objects.
Attached is the issue. You see the tree next to the building but I can't get it to be above the hotlink.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
I haven't run into this myself. Perhaps you need to set the display order in the source file of the module.
ares997
Thanks. That worked.
Good to know.
