door opening viewing ???
what do I do when the door is showing as closed on the model and but in the info box is open ?
is this a wall setting or a door setting ?
thanks all
myles.
1 Solution
Szabolcs Miko
Hi, that would be if their floor plan display is set to "projected"
check the following guide article: https://helpcenter.graphisoft.com/user-guide/76703/
If you would like to keep the projected view, but have the door opened, you can change their 3D opening angle in the door settings dialog:
Szabolcs Mikó
Manager, Customer Support
Go to post
Szabolcs Miko
Szabolcs Mikó
THANKS !! Worked well !!
