2017-07-30
11:17 PM
- last edited on
2023-05-25
04:55 PM
by
Rubia Torres
2017-08-16 02:32 PM
2017-08-16 04:19 PM
2018-10-18 04:00 AM
2018-10-18 05:47 AM
R wrote:
flat areas where each contour makes a "V" at the bottom of the valley. If I am modeling a ridge, my volume is too small because the incorrectly generated flat areas are at the top of the ridge
R wrote:
Here'e an update for AC22. ArchiCAD still generates incorrect typos. Here's an example of dead flat spots at the corners of a grading plan. It makes for lumpy topography and site areas that won't drain.
Yellow shaded areas have incorrect topography. Blue lines are user defined topo lines. Red lines are Archicad-defined ridges. Green lines are where ArchiCAD should have triangulated the lines in order to create real-world topography.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2018-10-18 08:29 PM
2018-10-19 04:48 AM
