2017-07-30
		11:17 PM
		2023-05-25
		04:55 PM
			Rubia Torres
2017-08-16 02:32 PM
2017-08-16 04:19 PM
2018-10-18 04:00 AM
2018-10-18 05:47 AM
R wrote:
flat areas where each contour makes a "V" at the bottom of the valley. If I am modeling a ridge, my volume is too small because the incorrectly generated flat areas are at the top of the ridge
R wrote:
Here'e an update for AC22. ArchiCAD still generates incorrect typos. Here's an example of dead flat spots at the corners of a grading plan. It makes for lumpy topography and site areas that won't drain.
Yellow shaded areas have incorrect topography. Blue lines are user defined topo lines. Red lines are Archicad-defined ridges. Green lines are where ArchiCAD should have triangulated the lines in order to create real-world topography.
2018-10-18 08:29 PM
2018-10-19 04:48 AM
