drawing lines at set angles to one another
I have not been able to find a solution to this problem: a line is drawn at 32˚, and I want to draw another line 15˚ from that one using the end point of line one as line 2's origin (orientation doesn't matter). Seems a simple "15˚ delta from line 1" but I cannot find a solution. This is a needed process for drawing site plans where the boundary survey is not in surveyor's North.....East measurements, but rather in degrees from the previous vector.
Thanks,
Rip Weaver, ASLA
Town Landscape Architect
The Town of Mt Laurel
Birmingham, ALABAMA
Mac 450 cube
OSX (10.2.
Archicad 8.1.0 v2
Rip,
Click on the 'align coordinates to item' (or whatever the 'real' name is!) button and then click on your first wall / line. When you draw the next line, starting from your endpoint you can enter the polar coordinate by typing "a15r100" or whatever.
Don't forget to click back to 'world ucs' (:o ) once you've finished.
- Stuart
Ralph Wessel
Rip wrote:
Seems a simple "15? delta from line 1" but I cannot find a solution.
You can specify an angle as an offset from the current angle in the Coordinates box. In your example:
A. Click on the origin of line 1 as your starting point for line 2.
B. Move your pointer to snap to the end of line 1 - you will notice that the angle field in the coordinates box is displaying the angle of line 1.
C. Without moving your pointer away, type the letter 'a' on your keyboard. This will highlight the angle field in the coordinates box.
D. Type in the offset angle for line 2, followed by the keypress '+' or '-' (plus or minus, depending on whether you want the offset to be added or subtracted).
E. The new offset angle will now be displayed in the coordinate box. It is probably best to lock it by typing <option-a> (for Mac) or <alt-a> (for Win). You can then extend line 2 to whatever length you wish.
Ralph Wessel BArch
Central Innovation
