editable Grid on Window will not join!
I'm creating a simple window from the object library, using the item "fixed Windows" with editable grid. I've increased the frame thickness, however I cannot get the inner vertical sash to meet the central horizontal sash.
I've attached a image but will most more upon request to see which setting needs altering. Editing the sash in elevation or 3D does not work
Thank You
0 Replies 0
