editing plane
I don't if it is me or what.
When in 3d I want to change editing plane, but after right clicking there is no option to set editing plane.
when go to view / 3d elements / editing plane there is everything frozen so commands for editing plane can not be run.
I have set to OpenGL, but it doesn't work.
what should I do?
David Maudlin
mzex:
You need to start an editing action in the 3D Window before the Editing Plane options become available. The type and plane of the action will help determine the Editing Plane direction options.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Figured that out, but thank you for your answer.
