Achille Pavlidis
elevation problem
Until now when changing the home story of an element (wall, stair, or other object) it retained its elevation.
Now in AC17 this is changed, and the elevation is relative to the offset from home story... This is extremely problematic when changing stories to multiple objects, one has to be careful and manually change the elevation of each and every one element to have the correct height.
Why is that?
Is there any solution?
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
3 Replies 3
Eduardo Rolon
The command to change the Home Story without moving in 3D is "Reassign Level"
enjoy the reading of the following topic
http://archicad-talk.graphisoft.com/viewtopic.php?t=42871&start=0&postdays=0&postorder=asc&highlight...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Achille Pavlidis
whoooa!!!
thanks ejrolon
Eduardo Rolon
Yep. Actually the command is "Relink Home Story" not "Reassign".
AC29 US/INT -> AC08
