elevations and roof fill
Hi, i'm not sure if this is possible,but i hope so:for roof - I want to have cover fill not only in stories,but also in elevation. i want to have it automaticly,not manually.thanks
7 Replies 7
Rod Jurich
starterr wrote:
........../ i want to have it automaticly,not manually.thanks
Is this what you are looking for?
Rod Jurich
Assign the fill pattern to the material on your roof (with Internal Engine selected in the Vectorial hatching tab, you probably want to change the fill pen too), and show vectorial fill in elevations as Rod indicated.
hi,I did as u said - still not appear in elevations.maybe there is another settings...
hi
the setting you're looking for is: Section settings (of the particular section/elevation you require), Model Display, Vectorial 3D Hatching - check it.
hope that helps...
Rod already said that.
i adjust elevation settings for current view-than it appeared.Great!Thank you!
Rod Jurich
Dober ono je ki dela
Rod Jurich
