embed curtain wall into a wall
Do anyone know knows how to embed curtain wall into a wall?
thank you
It is not possible to do.
You have to cut a hole into the Wall and move the Curtain Wall to its proper position.
You can use a Window for example to cut the hole. Or you can create a profiled Wall and using SEO subtract it from the sahep fo the Wall.
