error in 3d
i get this error when i try to see 3d
big project too many trees.
what should i buy? RAM? vga card? or clean up the hard drive??
down on the right you can see my free 'things'
really need some help here
thank you everyone!
4 Replies 4
Dwight
You need more disk space for Archicad's temporary files. These files are created distinct from the actual project file when a 3D view is made.
You can see where Archicad places these temporary files by reviewing your preferences and/or work environment.
In all probability, and the easiest solution, you need to ADD a hard drive. Then change Archicad's preference to this drive.
Dwight Atkinson
its not that d 40 GB that appears at the bottom of my screen?? or it is that and i need to have more?
Dwight
It is either a huge 3D file because of the foliage, or there's a corruption of an element that generates false data.
You could invest time in locating a possible corruption but you already seem certain that trees are causing the huge file....
So go figure.
Dwight Atkinson
yes i think the problem is the trees
so if the disk space is the problem i must ask again how much more space than the existing 40 GB i need?
or that number down there does not refer to that?
