explode
where is the explode commmand in archicad 10, i looked in the help index but all that does is explain what commands are it doesnt say where any of them are located for some reason
3 Replies 3
Laura Yanoviak
Edit Menu > Reshape > Explode...
Another comment maybe worth mentioning is that if you have "autogroup" turned on when you explode it, it will be grouped.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
That's because different Work Environments can locate them in different places.
CTRL = (CTRL and EQUAL key) is the default shortcut.
