explode
where is the explode commmand in archicad 10, i looked in the help index but all that does is explain what commands are it doesnt say where any of them are located for some reason
3 Replies 3
Laura Yanoviak
Edit Menu > Reshape > Explode...
Another comment maybe worth mentioning is that if you have "autogroup" turned on when you explode it, it will be grouped.
Gerald Hoffman
Archicad 4.55 - 30-Latest USA
2024 M4 Max MacBook Pro-OS Tahoe (128GB (16 Core CPU + 40 Core GPU)
That's because different Work Environments can locate them in different places.
CTRL = (CTRL and EQUAL key) is the default shortcut.
