exploding a polyline?
Hello.
It's a simple question. How can I explode a polyline into simple lines in Archicad ? Thank you.
8 REPLIES 8
Search results:
http://www.archicadwiki.com/results.html?q=explode%20polyline
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
Thank you for the reply. In one of the discussions one says the command is EXPLODE into current view. I posted the question precisely because nothing seems to happen to my polyline after this command.
Works fine. You must select the polyline before issuing the command. I tested in 16 since that is the version listed in your signature/profile.
The thread you mention is this one:
http://archicad-talk.graphisoft.com/viewtopic.php?p=207127#207127
Please add to an existing thread if the issue is the same subject, rather than starting a fresh thread. It makes it much easier for others to find an answer in the future. 🙂
You are right. From now on I will add to existing threads. In the mean time, I tried again exploding and it doesn't work. I am missing sth.
See Karl's image.
Tick the box to "keep primitives only" otherwise you will still have the original polyline as well as the individual lines hiding underneath.
I did and it's not working.
Just a shot in the dark but grouping is what I think of first when a command won't work where it should so you could try suspending groups by pressing ALT+G. I doubt it but maybe.
The shot in the dark solves the issue. That was it, indeed.
