Fills wont scale or rotate
Cover fills wont scale or rotate. Using the construction method I cant not alter the file scale or rotate it ..any ideas?
3 Replies 3
Eduardo Rolon
If I understand correctly you are asking how to modify a Cover Fill that is a applied to an object (slab for example). If that is the case the best way is to create a New cover fill with the needed parameters using Menu->Options->Element Attributes->Fill Types.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Link
Of course if you want a quick solution you could use a distorted fill then adjust the handles onscreen....
Link.
rocorona
If I understand correctly, you are seeing the bitmap version of the pattern, instead of the vector.
Go to View menu, On-Screen View Options, and select Vectorial Hatching.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
