Fills wont scale or rotate
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-12-13 03:51 AM
‎2013-12-13
03:51 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-13 02:32 PM
‎2013-12-13
02:32 PM
If I understand correctly you are asking how to modify a Cover Fill that is a applied to an object (slab for example). If that is the case the best way is to create a New cover fill with the needed parameters using Menu->Options->Element Attributes->Fill Types.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-13 06:22 PM
‎2013-12-13
06:22 PM
Of course if you want a quick solution you could use a distorted fill then adjust the handles onscreen....
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-16 02:13 PM
‎2013-12-16
02:13 PM
If I understand correctly, you are seeing the bitmap version of the pattern, instead of the vector.
Go to View menu, On-Screen View Options, and select Vectorial Hatching.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
