finishes aren't turning in section?
Can someone explain why the finishes aren't
turning into the opening in section like they do in plan?
See screenshots below, I put the plan view in this post and the section in the next.
Seems like everytime I turn around it's something else...Ugh, never ending Ugh.
Been trying not to think about having 24 building sections that don't show the top plates and sill plates.
Thanks
Here is the section view of the window above
See:
http://archicad-talk.graphisoft.com/viewtopic.php?t=44615
Karl,
Okay, it's a glitch.
I had tried the show in 3d radio button too, results were ridiculous.
I also noticed the other problem you mentioned and it's why my morph foam window surrounds are up a few stories and shown in plan in 2d line work...ugh.
The plaster/stucco edge in plan as it turns into the frame is not in the correct position / location. Guess I'll have to let this one go until graphisoft fixes this.
GRAPHISOFT!!
