Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
floor slabs show detail when a section cut is made......
I wish that when you created a floor slab you had options to build a composite floor similar to walls. Optiions like decking types, joist types and spacing, ceiling types and over all dimensions. This way when you cut a building section you can see this construction of the floor slabs.
1 REPLY 1
Laura Yanoviak
Composites are applicable to Slab and Roofs as well as Walls. You can create your own fills to represent decking, joists, etc. if you'd like (although we just typically use "Empty Fill" and "Wood Studs", respectively, because we don't do material take-offs). Additional graphics (symbol line types, for instance) would still need to be added to the section as they are for walls.
