free-form shapes
i like to know if i could achieve these shapes in archicad or would it be better to do it one another program if so which on. i'm using a mac computer
10 REPLIES 10
another picture
Dwight
Each plane would be made using the complex profile tool :
Define each shape as a fill, then extrude sideways as a wall.
See this:Eric Bobrow's great article
Dwight Atkinson
thanks a lot
TMA_80
hi
you could also try to use slab and save the result as an (rotated) object .
if you are a sketchup user there is a ruby script that seems let you do what you want easily ( slicer 3 )
http://www.pushpullbar.com/forums/showthread.php?9467-Visual-Index-of-Ruby-Scripts/page3
(i' haven't test it yet )
AC12_27 |Win11_64bit|
wow ruby scripts are amazing thanks as well
is it relatively easy to import and export from archicad to sketch up.for instance if i draw the pans in archicad can i make the 3d model in sketch up
TMA_80
As far as i know it is more "easy" to import from sketchup than to export . if you have a small model i think it will not be a problem as there will be less cleaning work to do .
thanks
Erich
Of course this is much harder to do with a mac. The sketch up import is currently functional for Windows only. If you have Bootcamp running then you can import on the Window side and copy your new objects to the Mac side.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
