RandyC
ghosted drag image
Not sure how to word this so i have had trouble searching for any
thread on it.
The ghosted image that appears when dragging an object , wall , slab
roof etc. is not showing - this happens intermittently on every plan -- I have to go to
the layout window , move something then return to working on the floorplan Has anyone had this issue ? We are experiencing it on all 4 of our
machines 10 to 20 times a day- becoming quite frustrating ( computer often
hangs shortly after or during these movements )
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
This sounds like a display driver issue... have you gone to the manufacturer web site to verify that you have the most current drivers? (I assume all 4 of your machines have the same or similar card?)
Or, it could be related to your 2D acceleration or antialiasing settings in your Work Environment?
RandyC
2D acceleration AND antialiasing are both off
I guess I will start looking at video drivers
(will let you know if this works)
Thanks, Carl
