2008-08-07 05:47 PM - last edited on 2023-05-25 04:57 PM by Rubia Torres
2008-08-07 06:50 PM
2008-08-07 06:51 PM
2008-08-07 07:26 PM
Karl wrote:Karl, you remind me now that hotlinks have changed to the point that they are not really compatible from 12 to 10 (nor even 11 really). They have to be redirected to compatible copies each time the project is reopened in a different version. I am working on projects where I have to save back to 11 in order to save as Navis files, so I have to maintain a fully parallel set of hot links in each version.
...so even if the hotlink manager is in your work environment, the 10 colleague cannot link multistory hotlinks, while you can - so all hotlinks should be done story by story.
The best bet is for you to just work in 10 on this particular project! If you don't have a 10 DVD, borrow your client's - every 12 key is authorized to run every prior version of AC.I agree with Karl on this. Unless you really need the speed of 12 (as I do on these huge projects) you are probably better off working in 10.
2008-08-07 08:17 PM
