how do you attach curtain wall to side walls?
I saw directions on how to connect walls to interior and exterior. What if you want the curtain wall to fit inside of a wall so that it has a header above? I pressed connect to wall but it did not work.
Thomas Holm
Place a door (or whatever) in the conventional wall and click the empty square to create an empty opening. Size it to the curtain wall. Place curtain wall in the opening.
thanx
