Braza wrote:
@Barry
I gave it a try and it was ok for me... Perhaps you forgot to "Apply to all edges".
What I meant (to be a little clearer) was is that sometimes it won't work if there is already a fillet/chamfer on another adjoining edge.
For example, now apply a chamfer to the front vertical edge of the morph in your image - that might work with a chamfer - but if you were dong fillets it wouldn't (at least not with the same radius).
Then apply a chamfer to the top horizontal edge - that won't work at all (even with a simple chamfer) when the other two adjoining edges are already chamfered.
But if you select all three connecting edges at the same time and fillet/chamfer and 'apply to all edges' it will work.
